NEC MultiSync E805 80" 1920x1080 4ms VGA DVI HDMI DP LED LFD
Quicklinx: B49SWS00 Mfr#: 60003929
  • 1080p
NEC's 80" large screen E805 delivers a cost-effective solution while maintaining high definition and contrast ratios for superior visual quality. The displays are ideal for boardroom, conference room and meeting room environments. The large size also makes it ideal for digital signage applications.
  • Carbon footprint meter
    Informs and motivates responsible use of the display by calculating and tracking the conservation of green gas emissions in real time.
  • LED edge-lit display
    Reduces overall depth while also lowering overall power consumption of the product.
  • Open pluggable specification (OPS)
    The first industry-wide standardization in option slots that allows for easier installation, use and maintenance of digital signage.
NEC MultiSync E805 E Series - 80" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
80"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, NaViSet Administrator 2
Energy Class
Class A+
430 Watt
Power Consumption (On mode)
139 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
203 kWh
183.6 cm x 8.7 cm x 106.1 cm
61 kg
3-year warranty
Energy Class
Class A+
430 Watt
139 W
203 kWh
Diagonal Class
80"
Commercial Use
Series
E Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode, Eco mode
Dimensions
Without stand
183.6 cm
8.7 cm
106.1 cm
61 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
4 ms
Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , LAN , Audio output , Speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
