For affordable digital signage applications yet with impressive screen performance, the MultiSync E424 features the edge LED backlight technology for an ultra slim design, light weight and very low power consumption.
- NEC MultiSync E424 42" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight - edge-lit
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Remote Control
- Standard remote
- Energy Class
- Class B
- 86 Watt
- Power Consumption (On mode)
- 69 W
- Energy Consumption per Year
- 101 kWh
- Dimensions (WxDxH) - without stand
- 95.7 cm x 6.3 cm x 57.3 cm
- 12.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
- Product Type
- Energy Class
- Class B
- 86 Watt
- 69 W
- 101 kWh
- Diagonal Class
- 42"
- Commercial Use
- TV Tuner
- No tuner
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Dimensions
- Without stand
- 95.7 cm
- 6.3 cm
- 57.3 cm
- 12.1 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Image Contrast Ratio
- 3000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6.5 ms
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
- Connector Type
- VGA input , 3 x HDMI , Digital audio output (optical) , Serial , USB , Composite video / component video input , Audio input , Audio input
- Cables Included
- VGA cable
- FCC Class B certified, CSA, UL, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Consumption Stand by
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
