NEC Multisync E223W 22" Wide Screen LCD (black) LED Backlights
Quicklinx: 911SWS00 Mfr#: 60003334
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: [N/A]
Interfaces: DisplayPort, DVI, VGA (HD-15)
More than 50 in stock
£155.51 ex VAT
£186.61 inc VAT
NEC MultiSync E223W features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a perfect feature set for the standard corporate office. The display offers 110 mm height adjustment and a broad connectivity with three inputs DisplayPort, DVI-D and D-Sub.
  • Image display
    22-inch 16:10 TN with LED backlight.
  • Ergonomic office
    Full height adjustability (110 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
  • VESA mount
    Allows installing the monitor via various mounting solutions.
NEC MultiSync E223W - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
HD 720p 1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
50.35 cm x 21.8 cm x 38.4 cm
5.6 kg
Environmental Standards
TCO Certified Displays 7, TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP
3-year warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, OSD lock
5.6 kg
DVI-D (HDCP) , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
25 Watt
Power Consumption Stand by
0.4 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
911S StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.29
911S StarTech.com Articulating Monitor Arm In Stock £103.13
911S StarTech.com Dual Monitor Stand In Stock £70.24
Diagonal Size: 22in
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: NEC
Price Range Ex VAT: 150 - 300
