The new MultiSync P801 PG with protection glass follows the tradition of NEC's professional large format display line. The high quality Conturan glass of Schott ensures reduced reflection and high light transmission for an unrestricted view of display content. Designed for a wide array of applications such as retail signage including 24/7, transport, corporate or control room P Series with protection glass offers flexible installation combined with industry leading performance.
- NEC MultiSync P801 PG P Series - 80" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 80"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, DisplayNote Presenter Licence, NaViSet Administrator 2
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 430 Watt
- Power Consumption (On mode)
- 232 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 339 kWh
- Dimensions (WxDxH) - without stand
- 183.62 cm x 9.69 cm x 106.13 cm
- 85.2 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 430 Watt
- 232 W
- 339 kWh
- Diagonal Class
- 80"
- Commercial Use
- Series
- P Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 183.62 cm
- 9.69 cm
- 106.13 cm
- 85.2 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Edge-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 5000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 4 ms
- Open Pluggable Specification slot
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , 2 x speakers output
- DisplayNote Presenter Licence, NaViSet Administrator 2
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
