NEC M333XS XGA DLP 3300 Lumens Projector
Quicklinx: BV1ZWS00 Mfr#: 60003974
Portability: Non-portable
£639.43 ex VAT
£767.31 inc VAT
Present with ease using the NEC M333XS, a value-driven, eco-friendly portable projector that delivers an ideal short throw distance solution for education (including interactive whiteboards) and corporate applications. This 3300-lumen model delivers remarkably bright images and features wired networking, HDMI and USB inputs, high contrast, remote monitoring, maintenance-free design, and up to 5000 hours of lamp life (in ECO mode). Its USB Viewer allows you to present without a PC by simply placing your presentation file onto a USB drive and plugging it into the projector's USB port.
  • Advanced AccuBlend
    Ensures detailed images when non-native resolution sources are connected to the projector.
  • AutoSense
    Intuitively syncs the projector with most computer signals and features one-touch image optimization.
  • Built-in closed captioning
    Enables decoding and display of text information from a video.
  • Built-in wall color correction
    Presets provide for adaptive color tone correction to display properly on non-white surfaces.
  • DLP technology
    High contrast images from Texas Instruments DLP engine featuring BrilliantColor technology with improved color accuracy.
  • Dual HDMI inputs (with HDCP)
    Ensure quick switching between presentations and allows for simultaneous digital connections of high-definition sources, such as Blu-ray players, cable boxes, satellite receivers and computers.
  • ECO mode
    Extends lamp life, lowers audible noise and reduces total cost of ownership.
  • Variable audio out
    Adjusts the volume of an external speaker system using the projector's remote control.
  • Virtual remote
    Used over the VGA cable to control the projector directly from a computer without the need for additional control cables.
NEC M333XS - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
3300 lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
270 Watt
Bulb life cycle
Up to 5500 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
278 Watt
36.8 cm x 28.6 cm x 9.7 cm
3.7 kg
3-year warranty
DLP projector
3D Capable
Projector
Brightness
3300 lumens
Contrast Ratio
10000:1
Image Size
152.4 cm - 381 cm
Projection Distance
0.68 m - 1.76 m
Throw Ratio
0.56:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
270 Watt
Bulb life cycle
Controls & Adjustments
Mute, volume, keystone correction, zoom, aspect control
Color Management System, JPEG photo playback, wall colour correction, Crestron RoomView, DICOM Simulation Mode, Direct Power Off, ImageCare Technology, auto power on, ambient light sensor, Carbon Savings Meter, Virtual Remote, sleep timer, Auto Eco Mode, High Altitude Mode, Projector Quick Connection
Lens
Focus Type
Manual
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
20 Watt
1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x RGB output - 15 pin D-Sub (DB-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone mono 3.5 mm , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x 3D Sync out - 3 PIN mini-DIN
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
TUV GS, RoHS, WEEE, GOST-R, ERP, EAC
Power Source
AC
Nominal Voltage
278 Watt
Power Consumption Stand by
0.4 Watt
Software Included
NaViSet Administrator 2
36.8 cm
28.6 cm
9.7 cm
3.7 kg
Limited warranty - 3 years , Limited warranty - light source - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
30 dBA
30 dBA
Brand: NEC
Price Range Ex VAT: 500 - 750
