Easy to use and at the right price, M series projectors provide all the essential features that you need to connect with your audience.
- NEC M311W - LCD projector - portable
- LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 3100 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 302 Watt
- 33.9 cm x 25.7 cm x 9.9 cm
- 2.99 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 3100 lumens
- Brightness (Reduced)
- 1860 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 63.5 cm - 762 cm
- Projection Distance
- 0.7 m - 14.7 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 230 Watt
- Bulb life cycle
- Freeze frame, Deep Color, Auto Power Off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.2
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B (management) , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- TUV GS, RoHS, WEEE, GOST-R, ERP
- Voltage Required
- 302 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- Software Included
- Drivers & Utilities
- 33.9 cm
- 25.7 cm
- 9.9 cm
- 2.99 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 28 dB
