NEC M311W WXGA LCD 3100 Lumens Projector
Quicklinx: 96QXWS00 Mfr#: 60003407
Easy to use and at the right price, M series projectors provide all the essential features that you need to connect with your audience.
NEC M311W - LCD projector - portable
LCD projector - 720p
Built-in Devices
Speaker
Brightness
3100 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
302 Watt
33.9 cm x 25.7 cm x 9.9 cm
2.99 kg
3-year warranty
Built-in Devices
Speaker
Projector
Brightness
3100 lumens
Brightness (Reduced)
1860 lumens
Contrast Ratio
3000:1
Image Size
63.5 cm - 762 cm
Projection Distance
0.7 m - 14.7 m
Throw Ratio
1.3 - 2.2:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
230 Watt
Bulb life cycle
Freeze frame, Deep Color, Auto Power Off
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.2
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B (management) , 2 x USB 2.0 - 4 pin USB Type A
Carrying case, wireless remote control
1 x VGA cable - 1.8 m
TUV GS, RoHS, WEEE, GOST-R, ERP
302 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
Drivers & Utilities
33.9 cm
25.7 cm
9.9 cm
2.99 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
35 dB
28 dB
