Get great performance while saving the environment. Advanced Eco features help to substantially lower your operating cost without compromising on quality and flexibility. Go wide with your presentations and play video content in native format. The M271X is particularly suited for classrooms and small to medium sized meeting rooms.
- NEC M271X - LCD projector - portable - LAN
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2700 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 180 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 239 Watt
- 33.9 cm x 25.7 cm x 9.9 cm
- 2.99 kg
- 3-year warranty
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 2700 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 63.5 cm - 762 cm
- Projection Distance
- 0.6 m - 13.8 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 180 Watt
- Bulb life cycle
- Controls & Adjustments
- Mute, keystone correction, aspect control, off timer
- Eco-Mode technology, Color Management System, freeze frame, Micro Lens Array (MLA) Technology, JPEG photo playback, wall colour correction, Auto Vertical Keystone, Deep Color, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Advanced Eco, Direct Power Off, Auto Power Off, Digital Zoom
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.2
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, security label, keypad lock
- TUV, GS, RoHS, WEEE, GOST-R, ERP
- Voltage Required
- 239 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- Software Included
- Drivers & Utilities
- 33.9 cm
- 25.7 cm
- 9.9 cm
- 2.99 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 26 dB
