Product
NEC M271X XGA Projector
Quicklinx: 8GFGWS00 Mfr#: 60003404
Get great performance while saving the environment. Advanced Eco features help to substantially lower your operating cost without compromising on quality and flexibility. Go wide with your presentations and play video content in native format. The M271X is particularly suited for classrooms and small to medium sized meeting rooms.
NEC M271X - LCD projector - portable - LAN
LCD projector
Built-in Devices
Speaker
Brightness
2700 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
180 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Video Modes
480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
239 Watt
33.9 cm x 25.7 cm x 9.9 cm
2.99 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
2700 lumens
Contrast Ratio
3000:1
Image Size
63.5 cm - 762 cm
Projection Distance
0.6 m - 13.8 m
Throw Ratio
1.3 - 2.2:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
180 Watt
Bulb life cycle
Controls & Adjustments
Mute, keystone correction, aspect control, off timer
Eco-Mode technology, Color Management System, freeze frame, Micro Lens Array (MLA) Technology, JPEG photo playback, wall colour correction, Auto Vertical Keystone, Deep Color, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Advanced Eco, Direct Power Off, Auto Power Off, Digital Zoom
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.2
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
Carrying case, lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, security label, keypad lock
TUV, GS, RoHS, WEEE, GOST-R, ERP
Nominal Voltage
239 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
Drivers & Utilities
33.9 cm
25.7 cm
9.9 cm
2.99 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
33 dB
26 dB
