NEC Iiyama EA193Mi 19" 1280x1024 6ms DVI VGA DisplayPort IPS LED Monitor
Quicklinx: 9RFNWS00 Mfr#: 60003585
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£149.53 ex VAT
£179.43 inc VAT
The EA193Mi is a high-end 19" 5:4 conventional format monitor with best IPS panel and latest energy saving LED backlight technology. It offers the latest DisplayPort connectivity and full ergonomic adjustability. Low power consumption and low operating costs make the display perfect for use in the professional office environment. Outstanding ergonomic comfort and intelligent features such as the Ambient Light Sensor make it very user-friendly and help to increase productivity.
  • Sets new standard in environmental compatibility
    The Ambient Light Sensor serves to increase energy saving even further. It measures the ambient light and adjusts the screen to the optimum brightness automatically without any manual settings being required. The use of recycling plastic for the monitor housing and of mercury-free materials fulfill the demands of the NEC "Green Vision" campaign.
  • The connection options ensure leading-edge compatibility
    With a DisplayPort, a DVI-D as well as an analog interface, the NEC MultiSync EA193Mi provides outstanding connectivity and the optimum basis for all business applications. The display also features speakers and a headphone socket for comfortable office communication.
  • Ergonomic and ecological characteristics
    Height adjustment through up to 110 mm and the pivot function allow the screen to be positioned to meet individual needs and ensure a high degree of userfriendliness. Thanks to its ergonomic and ecological characteristics, the monitor has gained TCO 6.0 certification and been awarded the EPEAT Silver Seal.
  • Eco-friendly display
    The eco-friendly display further extends the comprehensive range for the corporate sector. It helps to reduce running costs throughout the display's entire lifetime and its features make daily operations simpler and more productive. It is excellent value for money.
NEC MultiSync EA193Mi - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class A
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
White, silver
40.8 cm x 21.39 cm x 38.64 cm
6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP, TCO Displays 6.0
3-year warranty
Display Type
Energy Class
Class A
20 kWh
14 W
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour temperature
Ambient light sensor, No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, cable management cover, sRGB colour management, HDCP, NaViSet, Eco-Mode, Dynamic Visual Mode, OSD lock, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
White, silver
40.8 cm x 21.39 cm x 38.64 cm - with stand
6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) , DisplayPort , VGA (HD-15)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
18 Watt
Power Consumption Stand by
0.35 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 40.8 cm - depth: 6.5 cm - height: 33.8 cm - weight: 4 kg , With stand - width: 40.8 cm - depth: 21.39 cm - height: 38.64 cm - weight: 6 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
NEC Iiyama EA193Mi 19 Bundle deal on NEC Iiyama EA193Mi 19" 1280x1024 6ms DVI VGA DisplayPort IPS LED Monitor
£248.70
Diagonal Size: 19in
Response Time: 6ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: NEC
Price Range Ex VAT: 100 - 150
