Product
NEC EA244WMi 24" 1920x1200 VGA DVI-D HDMI IPS LED Monitor
Quicklinx: 97GDWS00 Mfr#: 60003414
NEC MultiSync EA244WMi features an extremely thin LED backlight panel with IPS technology which results in an ultramodern and slim design in combination with a premium feature set for the corporate office use. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability. Moreover the display offers broad connectivity with four inputs DisplayPort, HDMI, DVI-D and D-Sub. Thanks to its excellent IPS image quality with wide viewing angles in 16:10 screen format, it offers a high level of ergonomic comfort. Ideal for the corporate that demand style and future proof technology
  • Ultra-modern and slim design
    The product design is discrete and puts priority on the screen image and function.
  • Ambient light and human sensors
    The sensor technologies provide a perfect image with minimum power consumption.
  • Improved ergonomics
    The ergonomic stand with 130 mm height adjustability allows greatest set-up flexibility.
NEC MultiSync EA244WMi - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
55.62 cm x 23 cm x 40.89 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, TCO Certified Edge, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A+
31 kWh
21 W
Diagonal Size
24"
Viewable Size
24.1"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 60 Hz
Horizontal Refresh Rate
31.5 - 77 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, touch keys, ControlSync, OSD lock
7.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DisplayPort (HDCP) , HDMI , DVI-D (HDCP) , VGA , USB upstream (Type B) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x ControlSync cable , 1 x USB cable
Power Supply
Internal
29 Watt
Power Consumption Stand by / Sleep
0.47 Watt
0.47 Watt
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
