NEC's 80" large screen E805 delivers a cost-effective solution while maintaining high definition and contrast ratios for superior visual quality. The displays are ideal for boardroom, conference room and meeting room environments. The large size also makes it ideal for digital signage applications.
Carbon footprint meter
Informs and motivates responsible use of the display by calculating and tracking the conservation of green gas emissions in real time. -
LED edge-lit display
Reduces overall depth while also lowering overall power consumption of the product. -
Open pluggable specification (OPS)
The first industry-wide standardization in option slots that allows for easier installation, use and maintenance of digital signage.
- NEC MultiSync E805 E Series - 80" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 80"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, NaViSet Administrator 2
- Energy Class
- Class A+
- 430 Watt
- Power Consumption (On mode)
- 139 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 203 kWh
- Dimensions (WxDxH) - without stand
- 183.6 cm x 8.7 cm x 106.1 cm
- 61 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A+
- 430 Watt
- 139 W
- 203 kWh
- Diagonal Class
- 80"
- Commercial Use
- Series
- E Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Landscape mode, Eco mode
- Dimensions
- Without stand
- 183.6 cm
- 8.7 cm
- 106.1 cm
- 61 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 4 ms
- Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , LAN , Audio output , Speakers output
- NaViSet Administrator 2
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
- Power Device
- Power supply
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
