Product
NEC E705 70" 1920x1080 VGA DVI HDMI DP LED LFD
Quicklinx: CN7VWS00 Mfr#: 60003928#WPP
  • 1080p (Full HD)
The NEC MultiSync E705 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The 70 inch LCD-panel features a detail-rich Full HD resolution, eye-pleasing black levels for ergonomic viewing and state-of-the-art connectivity optimized to the needs of corporate applications. Thanks to an integrated ambient light sensor and latest LED backlight technology, the model features an amazingly low TCO with maintenance-free operation.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments.
NEC MultiSync E705 E Series - 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Energy Class
Class A++
320 Watt
Power Consumption (On mode)
89 W
Energy Consumption per Year
130 kWh
158.7 cm x 8.7 cm x 92 cm
47 kg
3 years warranty
Energy Class
Class A++
320 Watt
89 W
130 kWh
Diagonal Class
70"
Commercial Use
Series
E Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode, Eco mode
Dimensions
Without stand
158.7 cm
8.7 cm
92 cm
47 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , Network , Audio output , Speakers output
NaViSet Administrator 2
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
