NEC E505 Edge 50" 1920x1080 VGA HDMI LED Large Format Display
Quicklinx: BJKMWS00 Mfr#: 60003727
  • 1080p
The NEC MultiSync E505 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications.
Thanks to LED backlight technology, the display features an amazingly low TCO. Packed with integrated features like USB media player, speakers and scheduling function, E-Series models are also qualified for standalone applications in public environments.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/ 7.
NEC MultiSync E505 E Series - 50" LED-backlit LCD display - Full HD - for digital signage / hospitality
LED-backlit LCD flat panel display
Diagonal Class
50"
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
S-PVA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, 2 AAA batteries
Voltage
Energy Class
Class A
124 Watt
Power Consumption (On mode)
87 W
Energy Consumption per Year
127 kWh
112.36 cm x 7.7 cm x 64.67 cm
12.62 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
124 Watt
87 W
127 kWh
Diagonal Class
50"
Commercial Use
Series
E Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode
Dimensions
Without stand
112.36 cm
7.7 cm
64.67 cm
12.62 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
5000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
8 ms
Colour Temperature Control
Scheduler Function (with RTC)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Audio Controls
Equalizer
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
3 x HDMI - side , USB - side , Serial input - side , Composite video / component video input - rear , Audio input - rear , VGA input - rear , Audio input - rear , SPDIF output - rear
2 AAA batteries
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, DDC-2B, SASO, VESA DPMS, PSB, REACH
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel with stand - 112.36 cm x 25.5 cm x 68.37 cm x 13.12 kg , Panel without stand - 112.36 cm x 7.7 cm x 64.67 cm x 12.62 kg
20 - 80%
