The NEC MultiSync E325 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications.
Thanks to latest LED backlight technology, the display features an amazingly low TCO and maintenance-free operation. Packed with integrated features like USB media player, speakers and scheduling function, E-Series models are also qualified for standalone applications in public environments.
This display is ideal for education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/ 7.
- NEC MultiSync E325 32" LED-backlit LCD display - HD - for digital signage / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage / hospitality
- Black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class A
- Power Consumption (On mode)
- 36 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 53 kWh
- Dimensions (WxDxH) - without stand
- 72.7 cm x 7.7 cm x 42.4 cm
- 4.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 36 W
- 53 kWh
- Diagonal Class
- 32"
- Commercial Use
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Landscape mode
- Dimensions
- Without stand
- 72.7 cm
- 7.7 cm
- 42.4 cm
- 4.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 3000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6 ms
- Colour Temperature Control
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 100 x 100 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Equaliser
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x main channel speaker - 5 Watt
- Connector Type
- VGA input , Composite video / component video input , Audio line-in , 3 x HDMI , SPDIF output , Serial , Audio input , USB
- Cables Included
- VGA cable
- FCC Class B certified, UL, C-Tick, cUL, DDC-1, DDC-2B, SASO, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
