NEC C751Q 75" 3840x2160 8ms HDMI LED Large Format Display
Quicklinx: DS16WS00 Mfr#: 60004315
TV Tuner Presence: No
Video Interface: HDMI
£2,872.93 ex VAT
£3,447.51 inc VAT
Enhance your meeting and conferencing performance with stunning resolution. Get quality and reliability at a low total cost of ownership. Professional haze levels ensure great visibility without distracting reflections - along with high brightness, the NEC MultiSync C series meets the demands of meeting environments. Slim bezels and a modern appearance complement state of the art architecture to integrate perfectly into interior designs.
  • Modern and slim design
    Robust yet elegant allowing for an unobtrusive integration into any application and environment.
  • 24/7 operation
    The meticulous selection of industrial-grade components and careful design focused on demanding usage scenarios accompany an impressive and continuous viewer experience.
  • Ease of use and operation
    Smart installation, operation and maintenance functionality ensures accurate performance over the entire lifetime of the display saving time, effort and resources.
NEC MultiSync C751Q C Series - 75" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HLG10
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Max Number of Screens
100
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DisplayPort
IPS
LCD Backlight Technology
Edge-lit LED local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support, KeyGuide
Speaker System
2 speakers
Supported Memory Cards
microSDHC
USB
Remote control
Voltage
Energy Class
Class G
195 Watt
Power Consumption (On mode)
165 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
314 kWh
168.1 cm x 7.1 cm x 96 cm
53 kg
3-year warranty
Energy Class
Class G
195 Watt
165 W
165 kWh/1000h
314 kWh
Diagonal Class
75"
Commercial Use
Series
C Series
HDR Capable
HDR Format
HLG10
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DisplayPort
Modes
Portrait mode, landscape mode, Eco mode
Design
Slim Bezel Design
Dimensions
Without stand
168.1 cm
7.1 cm
96 cm
53 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED - local dimming
Coating
28% haze
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Crestron Connected Compatible, Scheduler, Expansion Slot, DICOM support, NaViSet Administrator 2, AMX NetLinx support, PJLink, Raspberry Pi Compute Module Compatible, OmniColor, 12-bit Look Up table, ASCII Control Commands, emergency notification, PIN as theft protection, pixel-free, removable logo
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm, 600 x 400 mm
Video Features
Supported Computer Resolutions
1920 x 1080, 3840 x 2160, 4096 x 2160, 1920 x 2160
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, MOV, FLV
Supported Audio Formats
MP3, WAV
Supported Pictures Formats
JPG, PNG
microSDHC
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
3 x HDMI , 2 x DisplayPort input , Audio input , LAN , Remote control , RS-232 , USB 2.0 downstream , USB 2.0 , USB 2.0 upstream , DisplayPort output , Audio output , PoweredUSB , Service , 2 x speakers output
DisplayPort cable , USB cable
CSA, UL, TUV GS, VCCI, cUL, SASO, VESA DPMS, VESA FDMI, FCC, EMC Class B, EAC, IP5X, DisplayPort 1.2, HDCP 2.2, HDCP 1.3, HDCP 1.4, IP2X
Power supply
Input Voltage
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
Brand: NEC
Price Range Ex VAT: £1500+
