NEC AccuSync  21.5" Wide Black with Speakers
Quicklinx: 912HWS00 Mfr#: 60003496
21.5" 16:9 wide LCD with TN TFT display features green product design using the latest LED backlight technology at an affordable price. The attractively designed display comes with VGA and DVI-D input. The ideal monitor is for entry-level, corporate and demanding consumers.
NEC AccuSync AS222WM - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Panel Type
TN
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Voltage
50.74 cm x 20.51 cm x 36.47 cm
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, PCT, VESA EDID, TUV Ergo, ISO 9241-307, ERP
3-year warranty
Display Type
Energy Class
Class A
26 kWh
Diagonal Size
21.5"
Panel Type
TN
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Tilt
Rapid Response, HDCP, Eco-Mode, OSD lock, Carbon Savings Meter
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) , VGA
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable
Power Supply
Internal
Input Voltage
18 W
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.35 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
