NEC 80" Full HD 1920 x 1080 LED Backlit LCD Display
Quicklinx: CBWTWS00 Mfr#: 60003481
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£6,124.71 ex VAT
£7,349.65 inc VAT
The reference MultiSync P801 is the flagship model in the P series range, giving the ultimate size and quality image for content that will capture the imagination and attention of your visitors. The display can be pre-configured before it is installed via the Android app and NFC sensor offer saving installation time and cost. A focus is also placed on reducing power consumption and lowering running costs with the LED backlighting and human sensor which can manage the power of the display depending upon viewer proximity. This display is ideal for any heavy duty application from retail to control rooms or as a projector replacement in high brightness meeting rooms and can be combined with an integrated OPS Wi-Di.
NEC MultiSync P801 P Series - 80" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
80"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
Energy Class
Class A
430 Watt
Power Consumption (On mode)
232 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
339 kWh
183.62 cm x 8.69 cm x 106.13 cm
61.5 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays
3-year warranty
Energy Class
Class A
430 Watt
232 W
339 kWh
Diagonal Class
80"
Commercial Use
Series
P Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
183.62 cm
8.69 cm
106.13 cm
61.5 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.9225 mm
Response Time
4 ms
NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
TCO Certified
Input Voltage
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
Brand: NEC
Price Range Ex VAT: £1500+
