NEC's 42" V423 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V423's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This Full HD model features built-in speakers and an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and corporate boardrooms.
Advanced cooling system
It prevents the likeliness of image retention and improves color uniformity. -
LED edge-lit display
It enables a mere 1.7" unit depth, creating installation opportunities in even the tightest of spaces. -
PIP/POP/side-by-side
Picture-in-picture (PIP) allows for a second frame within the screen area. Picture-on-picture (POP) surrounds the standard frame with multiple frames. Side-by-side places two sources adjacent to one another. -
Round-the-clock scheduler
Allows for advanced scheduling of monitor powering up/down, increasing panel lifetime, reducing power consumption and saving the time and expense of finding and purchasing a third-party scheduling solution. -
Text ticker
It creates a dedicated portion of the screen for applications such as news updates and emergency warnings. -
TileMatrix
It allows users to customize a video wall configuration using advanced On Screen Display controls.
- NEC MultiSync V423 V Series - 42" LED-backlit LCD display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- DICOM Simulated Gamma
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 220 Watt
- Power Consumption (On mode)
- 89 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 130 kWh
- Dimensions (WxDxH) - without stand
- 97.25 cm x 6.83 cm x 56.54 cm
- 16.8 kg
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 220 Watt
- 89 W
- 130 kWh
- Diagonal Class
- 42"
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Eco mode
- Cooling System
- Fanless
- Dimensions
- Without stand
- 97.25 cm
- 6.83 cm
- 56.54 cm
- 16.8 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Serial input , Serial output , Remote control input , 2 x speakers output , Audio input , Audio output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
