NEC 24" 1920 x 1080 6ms DVI Height Adjustable LED Monitor
Quicklinx: B3G1WS00 Mfr#: 60003681
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort, DVI, VGA (HD-15)
31 in stock
£139.18 ex VAT
£167.01 inc VAT
The 24" NEC MultiSync E243WMi is an LED-backlit desktop monitor ideal for corporate environments. Designed to enhance work performance, this widescreen model features AH-IPS panel technology with wide viewing angles (178° horizontal/vertical) and full ergonomic adjustability. The LED backlighting of the E243WMi allows for a slimmer profile, lighter weight and increased power savings compared to previous generation models. This 16:9, Full HD display also features a comprehensive input panel, including DisplayPort, DVI-D and VGA connecting users to the latest peripherals and future-proofs the investment. Integrated multimedia speakers enhance the user's experience.
NEC MultiSync E243WMI-BK - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.28 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
55.78 cm x 21.39 cm x 37.96 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.28 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Ambient light sensor, XtraView, AccuColor Control Systems, Rapid Response, No Touch Auto Adjust, Ambix, Intelligent Power Manager (IPM), HDCP, Eco-Mode, Dynamic Visual Mode, OSD lock, Touch-sensitive OSD, Carbon Footprint Meter, NaViSet Administrator 2
55.78 cm x 21.39 cm x 37.96 cm - with stand
6.3 kg
DisplayPort , DVI-D , VGA (HD-15) , Headphones , Audio line-in
Mechanical
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Cable organizer
1 x VGA cable , 1 x DVI cable , 1 x audio cable
19 Watt
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Without stand - width: 55.78 cm - depth: 5.85 cm - height: 33.14 cm - weight: 4.3 kg , With stand - width: 55.78 cm - depth: 21.39 cm - height: 37.96 cm - weight: 6.3 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
NEC 24 Bundle deal on NEC 24" 1920 x 1080 6ms DVI Height Adjustable LED Monitor
£238.35
B3G1 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
B3G1 StarTech.com Articulating Monitor Arm In Stock £101.86
B3G1 StarTech.com Dual Monitor Stand In Stock £69.36
B3G1 StarTech.com Cubicle Monitor Hanger In Stock £45.29
B3G1 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
Response Time: 6ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: NEC
Price Range Ex VAT: 100 - 150
