NEC MultiSync EA223WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics with 130mm height adjustability. Moreover the display offers broad connectivity with three inputs DisplayPort, DVID and D-Sub.
Ideal for the corporate that demand style and future proof technology.
Ambient light sensor
With auto brightness function always sets optimized brightness level according to ambient light and content conditions. -
Ergonomic office
Full height adjustability (130mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic setup. -
Feature set for perfect office use
Integrated speakers, headphone jack and USB hub provide excellent options for office communication. -
Green product concept
Eco mode and carbon footprint meter/carbon savings meter, ambient light sensor. -
Human sensor
Detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user. -
Image display
22-inch 16:10 TN with LED backlight. -
VESA mount (100mm)
Allows to install the monitor via various mounting solutions.
- NEC MultiSync EA223WM - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A
- Energy Consumption per Year
- 18 kWh
- Power Consumption (On mode)
- 12 W
- Stereo speakers, USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- HD 720p 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Black
- 50.4 cm x 21.8 cm x 38.4 cm
- 5.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 18 kWh
- Diagonal Size
- 22"
- Built-in Devices
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 82.3 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, Eco-Mode, ControlSync
- Black
- 50.4 cm x 21.8 cm x 38.4 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , 4 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Audio line-in
Mechanical
- Tilt Angle
- 35
- Swivel Angle
- 240
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x USB cable , 1 x DisplayPort cable , 1 x ControlSync cable
- Power Supply
- Internal
- 12 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
