NEC 22" Multisync EA224WMI Black LED
Quicklinx: 9127WS00 Mfr#: 60003336
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£174.90 ex VAT
£209.88 inc VAT
NEC's 22" MultiSync EA224WMi uses a premium-grade IPS panel, which provides wide viewing angles, outstanding color consistency and image accuracy. Its LED backlighting technology allows a thinner, lighter and sleeker design, as well as higher power efficiency. This EPEAT Gold model includes DisplayPort, HDMI, DVI-D and VGA D-Sub inputs, as well as an integrated 4-port USB 2.0 hub to connects you to the latest peripherals. Touch-sensitive controls enable simple display adjustments through the EA224WMi's On Screen Display (OSD), while integrated smart sensing technology includes ambient light and human sensors to automatically determine the proper display brightness and detect the absence of the user, both of which reduce power consumption and prolong product life.
NEC MultiSync EA224WMi - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
50.7 cm x 21.8 cm x 37 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, TUV Ergo, RoHS, ISO 9241-307, GEEA
3-year warranty
Display Type
Energy Class
Class B
37 kWh
25 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Infrared user sensor, ambient light sensor, Intelligent Power Manager (IPM), sRGB colour management, NaViSet
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , VGA , 4 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Audio line-in , HDMI
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x USB cable , 1 x audio cable , 1 x VGA cable , 1 x DVI cable
Power Supply
Internal
26 Watt
Power Consumption Stand by / Sleep
0.43 Watt
0.43 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
NEC 22 Bundle deal on NEC 22" Multisync EA224WMI Black LED
£274.07
Diagonal Size: 22in
Response Time: 14ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: NEC
Price Range Ex VAT: 150 - 300
