Nanoleaf Light Panels - Rhythm Smarter Kit
Quicklinx: DDQ3WS00 Mfr#: NL28-2002TW-9PK
Nanoleaf Light Panels - Rhythm Edition
The Smarter Kit includes everything you need to get started and the Rhythm Upgrade module! Add up to 30 panels to this WiFi smart lighting product and bathe any room in gorgeous, colorful light. Operate with the free Nanoleaf Smarter Series App or the Home App in iOS10+. And if you don't want to use your phone as a lightswitch, you can access basic functions from the controller buttons and with Siri, Google Home / Assistant or Amazon Alexa.
Works with iOS8 or later (HomeKit), Android 5.01 or later and Google Assistant, Apple Home App, Amazon Alexa, and IFTTT. Includes 9 Panels, the Rhythm Module, and everything else you need to get started.
Nanoleaf Rhythm Edition Smarter Kit - wireless lighting set - LED x 9
Wireless lighting set
Light Source Type
9 x LED
Supported Light Bulbs Qty
30
Intelligent Assistant
Siri, Google Assistant, Alexa
Platform
Apple HomeKit, Google Home, IFTTT
Communications Technology
Wi-Fi
30
Light Source
9 x LED
Built-in LED Lamp
Android compatible, iOS compatible
Internet of Things (IoT)
Platform
Wi-Fi
Warranty
2 years
25.5 cm
32 cm
9 cm
2.18 kg
2.78 kg
