MSI Z370I GAMING PRO CARBON AC Intel Z370 S1151 DDR4 mini-ITX
Quicklinx: D53VWS00 Mfr#: Z370I GAMING PRO CARBON AC
  • Bluetooth 4.0
  • IEEE 802.11n
  • Bluetooth 3.0
• Supports 8th Gen Intel® Core™ / Pentium® Celeron® processors for LGA 1151 socket
• Supports DDR4 Memory, up to 4600+(OC) MHz
• Lightning Fast Game experience: 1x TURBO M.2, Intel Optane Memory Ready. LIGHTNING USB 3.1 GEN2
• AUDIO BOOST 4 with Nahimic 2+: Reward your ears with studio grade sound quality for the most immersive gaming experience
• DDR4 Boost with STEEL ARMOR: Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost.
• GAMING LAN and Wireless support, powered by Intel®: The best online gaming experience with lowest latency and bandwidth management.
• VR Ready: Best virtual reality game experience without latency, reduces motion sickness
• Military Class 5, Guard-Pro: Latest evolution with high quality Japanese components for best protection and efficiency
• In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost, WTFast
• EZ Debug LED: Easiest way to troubleshoot
• Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function
• GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players
  • Stay cool while gaming
    Cooling your PC is essential for reliable performance. MSI made sure to include enough fan headers with full control to allow you to cool your system any way you want.
  • Be the first on the battlefield
    This MSI GAMING motherboard supports a lot of storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies.
  • Immerse yourself into virtual worlds
    Integrating cutting edge technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience in which content truly comes alive.
  • Sound that pulls you into the game
    Get an immersive sound experience when gaming. MSI Audio Boost delivers the high sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create exciting gameplay.
  • Dominate the game with low latency
    Get ready to crush your enemies on the battlefield with MSI GAMING LAN, featuring the high quality components tuned to deliver amazing online gaming experience without lag.
  • Unmatched memory performance
    MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
MSI Z370I GAMING PRO CARBON AC - motherboard - mini ITX - LGA1151 Socket - Z370
Motherboard - mini ITX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2667 MHz, 2800 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4500 MHz (O.C.), 4400 MHz (O.C.), 4266 MHz (O.C.), 4333 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Controller
Intel I219V / Intel Dual Band Wireless-AC 8265
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DisplayPort , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, MSI Military Class V, LAN Protect, 3D printing friendly, Intel Optane Memory Ready, MSI Audio Boost 4, Nahimic 2+ Sound Technology
I/O back plate
1 x SLI bridge , Serial ATA cable
Software Included
Drivers & Utilities, MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI CPU-Z, MSI X-BOOST
17 cm
17 cm
