MSI Z370 SLI PLUS Intel Z370 S1151 DDR4 USB3.1Gen2 ATX
Quicklinx: D53QWS00 Mfr#: Z370 SLI PLUS
Personalize your PC with numerous colors and effects, controlled in one click with the mobile device.
  • Lightning USB 3.1 Gen2
    Powered by the ASMedia ASM3142 USB 3.1 Gen2 controller, Lightning USB offers the fast USB speeds at low power usage.
  • Audio Boost 4
    Reward your ears with studio-grade sound quality for the immersive audio experience.
  • Professional I/O cover and heatsink
    Stunning looks, protecting the I/O ports.
  • PCI-E Steel Armor
    Protecting VGA cards against bending and EMI.
  • TwinTurbo M.2
    NVMe support, using PCI-Express Gen3 x4.
  • DDR4 boost
    Optimized traces and isolated memory circuitry.
  • Military Class 5
    High-quality components for perfect protection and efficiency.
MSI Z370 SLI PLUS - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
RAM Supported
4 DIMM slots - DDR4
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
DDR4
Bus Clock
4000 MHz (O.C.)
Dual channel memory architecture
Audio
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, MSI Mystic Light, MSI Steel Armor, MSI Military Class V, MSI Audio Boost 4
30.5 cm
24.4 cm
3.81 cm
