Personalize your PC with numerous colors and effects, controlled in one click with the mobile device.
Lightning USB 3.1 Gen2
Powered by the ASMedia ASM3142 USB 3.1 Gen2 controller, Lightning USB offers the fast USB speeds at low power usage. -
Audio Boost 4
Reward your ears with studio-grade sound quality for the immersive audio experience. -
Professional I/O cover and heatsink
Stunning looks, protecting the I/O ports. -
PCI-E Steel Armor
Protecting VGA cards against bending and EMI. -
TwinTurbo M.2
NVMe support, using PCI-Express Gen3 x4. -
DDR4 boost
Optimized traces and isolated memory circuitry. -
Military Class 5
High-quality components for perfect protection and efficiency.
- MSI Z370 SLI PLUS - motherboard - ATX - LGA1151 Socket - Z370
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z370
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z370
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Technology
- DDR4
- Bus Clock
- 4000 MHz (O.C.)
- Dual channel memory architecture
Audio
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- Hardware Features
- NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, MSI Mystic Light, MSI Steel Armor, MSI Military Class V, MSI Audio Boost 4
- 30.5 cm
- 24.4 cm
- 3.81 cm
