16.8 million colors/17 effects controlled in one click. Mystic Light Sync supports both RGB and Rainbow LED strip. Reward your ears with studio grade sound quality for the most immersive gaming experience. Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost.
Mystic Light
16.8 million colors/17 effects controlled in one click. Mystic Light Sync supports both RGB and Rainbow LED strip. -
Lightning fast game experience
2x TURBO M.2, Intel Optane Memory Ready. M.2 Shield, Lightning USB 3.1 Gen2. -
Audio Boost 4 with Nahimic 2+
Reward your ears with studio grade sound quality for the most immersive gaming experience. -
DDR4 Boost
Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost. -
Gaming LAN and wireless support
Powered by Intel: the best online gaming experience with lowest latency and bandwidth management. -
Multi-GPU
With Steel Armor PCI-E slots. Supports 2-way NVIDIA SLI and 3-way AMD Crossfire.
- MSI Z370 GAMING PRO CARBON AC - motherboard - ATX - LGA1151 Socket - Z370
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z370
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z370
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Technology
- DDR4
- Bus Clock
- 4000 MHz (O.C.)
- Dual channel memory architecture
Audio
- High Definition Audio
LAN
- Network Controller
- Intel I219V / Intel Dual Band Wireless-AC 8265
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DisplayPort , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- Hardware Features
- NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, MSI Mystic Light, MSI Steel Armor, MSI Audio Boost 4, Nahimic 2+ Sound Technology
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities
- 30.5 cm
- 24.4 cm
- 3.81 cm
