MSI Z370 GAMING PRO CARBON AC Intel Z370 S1151 ATX
Quicklinx: D53KWS00 Mfr#: Z370 GAMING PRO CARBON AC
16.8 million colors/17 effects controlled in one click. Mystic Light Sync supports both RGB and Rainbow LED strip. Reward your ears with studio grade sound quality for the most immersive gaming experience. Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost.
  • Mystic Light
  • Lightning fast game experience
    2x TURBO M.2, Intel Optane Memory Ready. M.2 Shield, Lightning USB 3.1 Gen2.
  • Audio Boost 4 with Nahimic 2+
  • DDR4 Boost
  • Gaming LAN and wireless support
    Powered by Intel: the best online gaming experience with lowest latency and bandwidth management.
  • Multi-GPU
    With Steel Armor PCI-E slots. Supports 2-way NVIDIA SLI and 3-way AMD Crossfire.
MSI Z370 GAMING PRO CARBON AC - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
RAM Supported
4 DIMM slots - DDR4
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11ac
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
DDR4
Bus Clock
4000 MHz (O.C.)
Dual channel memory architecture
Audio
High Definition Audio
LAN
Network Controller
Intel I219V / Intel Dual Band Wireless-AC 8265
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DisplayPort , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, MSI Mystic Light, MSI Steel Armor, MSI Audio Boost 4, Nahimic 2+ Sound Technology
I/O back plate
2 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities
30.5 cm
24.4 cm
3.81 cm
