MSI Z370 GAMING M5 Intel Z370 S1151 DDR4 PCIe3.0 USB3.1G2 ATX
Quicklinx: D53GWS00 Mfr#: Z370 GAMING M5
Personalize your PC with numerous colors and effects, controlled in one click with the mobile device.
  • Twin Turbo M.2 with M.2 Shield V2
    Onboard M.2 thermal solution to keep M.2 hard drives safe, while preventing throttling, making them run cooler and faster.
  • Lightning USB 3.1 Gen2
    Powered by the ASMedia ASM3142 USB 3.1 Gen2 controller, Lightning USB offers the fast USB speeds at low power usage.
  • Audio Boost 4
    Isolated audio with a high-quality audio processor and Nahimic 2+ for the immersive gaming experience.
  • DDR4 Boost with Steel Armor
    Fully isolated and shielded DIMM slots to protect DDR4 modules and deliver pure data signals for optimal gaming and overclocking.
MSI Z370 GAMING M5 - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
RAM Supported
4 DIMM slots - DDR4
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 3 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
DDR4
Bus Clock
4000 MHz (O.C.)
Dual channel memory architecture
Audio
High Definition Audio
LAN
Network Controller
Killer Gaming E2500
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x DisplayPort
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, Clear CMOS Button, MSI Gaming Device Port, MSI Mystic Light, MSI Steel Armor, MSI Audio Boost 4, Nahimic 2+ Sound Technology
I/O back plate
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities
30.5 cm
24.4 cm
3.81 cm
