Master the Game
With a unique look and feel, packed with exclusive gaming features, MSI ENTHUSIAST GAMING motherboards offer the best possible gaming experience.
• Supports 7th / 6th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1151 socket
• Supports DDR4-4133+(OC) Memory
• DDR4 Boost with Steel Armor: Give your DDR4 memory a performance boost
• VR Ready and VR Boost: Best virtual reality game experience without latency, reduces motion sickness
• OC DASHBOARD: The ultimate overclocking tool to experience easier on-the-fly overclocking
• USB Xpander: For more controllable devices and flexible usage with USB 2.0 in-chassis connectors
• Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click
• Triple Turbo M.2, Steel Armor, M.2 Shield. Intel Optane Memory Ready, Turbo U.2, Lightning USB 3.1 Gen
• Audio Boost 4 with Nahimic 2: Reward your ears with studio grade sound quality for the most immersive gaming experience
• Dual GAMING LAN with LAN Protect, powered by Intel® : The best online gaming experience with lowest latency and bandwidth management
• BIOS Flashback+: Easy BIOS recovery without the need of a CPU, memory and VGA card
• Military Class 5, Guard-Pro: Latest evolution in high quality components for best protection and efficiency
• MULTI-GPU: With Steel Armor PCI-E slots. Supports NVIDIA SLI™ & AMD Crossfire™
• In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost, Xsplit Gamecaster
• EZ Debug LED: Easiest way to troubleshoot
• Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function
• GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players
Stay cool while gaming
Cooling your PC is essential for reliable performance. They have made sure to include enough fan headers with full control to allow you to cool your system any way you want. -
Be the first on the battlefield
This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Sound that pulls you into the game
Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay. -
Dominate the game with the lowest latency
Get ready to crush your enemies on the battlefield with MSI GAMING LAN. Featuring the highest quality components tuned to deliver the best online gaming experience without lag. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
- MSI Z270 XPOWER GAMING TITANIUM - motherboard - ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA-600, 3 x M.2, 1 x U.2 ports
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 3 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.), 4000 MHz (O.C.)
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC1220
- High Definition Audio
LAN
- Network Controller
- Intel I219V / I211-AT
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 4 x PCIe 3.0 x16 (x16, x0, x0, x4 or x8, x0, x8, x4 or x8, x4, x4, x4 modes) , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 3 x M.2 - RAID , PCIe 3.0 -connectors: 1 x U.2 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x DisplayPort
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector, 6-pin ATX12V connector
- BIOS Features
- BIOS FlashBack+, MSI ClickBIOS 5
- Hardware Features
- Teaming Technology, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, AMD 4-way CrossFireX technology support, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, MSI Military Class V, LAN Protect, OC Dashboard, Intel Optane Memory Ready, MSI Audio Boost 4, Nahimic 2 Sound Technology, USB Xpander
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, MSI X-BOOST
- 30.5 cm
- 24.4 cm
