- Supports 7th / 6th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1151 socket
- Supports DDR4-3866+(OC) Memory
- DDR4 Boost with Steel Armor: Give your DDR4 memory a performance boost
- VR Ready and VR Boost: Best virtual reality game experience without latency, reduces motion sickness
- Mystic Light and Mystic Light Sync: 16.8 milliom colors /17 effects controlled in one click with GAMING APP or mobile devices.
- Lightning Fast Game experience: Twin Turbo M.2, Steel Armor, M.2 Shield. Intel Optane Memory Ready, Lightning USB 3.1 Gen2
- Audio Boost 4 with Nahimic 2: Reward your ears with studio grade sound quality for the most immersive gaming experience
- GAMING LAN with LAN Protect, powered by Intel® : The best online gaming experience with lowest latency and bandwidth management
- Military Class 5, Guard-Pro: Latest evolution in high quality components for best protection and efficiency
- MULTI-GPU: With Steel Armor PCI-E slots. Supports NVIDIA SLI™ & AMD Crossfire™
- In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost, Xsplit Gamecaster
- EZ Debug LED: Easiest way to troubleshoot
- Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function
- GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players
Personalize your gaming
Customize and set up your own color scheme with RGB Mystic Light. Select any of the colors from the palette to match your system style. Bored of the same colors? Simply change the complete look of your system! -
Stay cool while gaming
Cooling your PC is essential for reliable performance. Enough fan headers with full control are provided to allow you to cool your system any way you want. -
Sound that pulls you into the game
Get an immersive sound experience when gaming. MSI Audio Boost delivers the high sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create exciting gameplay. -
Dominate the game with the low latency
Get ready to crush your enemies on the battlefield with MSI gaming LAN, featuring the high quality components tuned to deliver a perfect online gaming experience without lag.
- MSI Z270 GAMING PRO CARBON - motherboard - ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC1220
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 (x16, x0, x4 or x8, x8, x4 modes) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, AMD 3-way CrossFireX technology support, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, MSI Military Class V, LAN Protect, Intel Optane Memory Ready, MSI Audio Boost 4, Nahimic 2 Sound Technology
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, MSI X-BOOST
- 30.5 cm
- 24.4 cm
