MSI Z170I GAMING PRO AC Intel Z170 S1151 DDR4 M.2 USB3.1
Quicklinx: BMP9WS00 Mfr#: Z170I GAMING PRO AC
  • Bluetooth 4.0
  • IEEE 802.11n
  • Bluetooth 3.0
Engineered to provide both a stunning gaming and visual experience, the MSI Z170 Performance GAMING series give you plenty of reasons to show off. The MSI Z170A GAMING PRO AC is an extremely customizable platform, allowing you to display your unique style with Mystic Light while placing a vast array of powerful gaming features at your disposal.
MSI Z170I GAMING PRO AC - motherboard - mini ITX - LGA1151 Socket - Z170
Motherboard - mini ITX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
4 x USB 3.1 Gen 1 + 3 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 4 x USB 3.1 Gen 1 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 3 x USB 2.0 , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
MSI Military Class IV, overcurrent protection, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Audio Boost 3, LAN Protect, Double ESD Protection, SteelSeries Certified (SSC), MSI VGA Armor, overvoltage protection, MSI USB Audio Power Pro
2 aerials, cable labels, I/O back cover
Software Included
RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI DPC Latency Tuner
17 cm
17 cm
