Product
MSI Z170A PC MATE Intel Z170 LGA1151 DDR4 PCIe M.2 USB 3.1 ATX
Quicklinx: BJPRWS00 Mfr#: Z170A PC MATE
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
  • Unmatched memory performance and stability
    With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability.
  • OC Genie 4
    OC Genie is the world's first built-in hardware overclocking technology on motherboards. With this one-second overclocking option we're giving you even more performance. Just hit the button and your PC gets another adrenalin shot.
  • The award-winning CLICK BIOS 5
    Explore the greatly improved, award-winning CLICK BIOS 5 and use it to tune your system to maximum performance. MSI CLICK BIOS 5 is the next generation UEFI BIOS with optimizations for Windows 10.
  • Stable, secure networking
    The Gigabit network adapter on MSI Professional motherboards offers fast, reliable and secure networking.
  • Easy diagnostic
    MSI EZ Debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU / memory / VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly.
  • Enhanced CPU overvoltage protection
    Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let's you know that overvoltage protection is activated for easier troubleshooting.
  • Optimized for multiple graphics cards
    This motherboard supports AMD CrossFire. Optimal PCI-Express slot placement allows for better fitting and airflow. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running an AMD CrossFire setup.
  • Total fan control
    Total fan control gives you complete control of all your fans connected to the motherboard, through a revolutionary and easy to use interface.
  • Legacy DVI/VGA video support
    To support professional monitors, TV's, beamers and other displays, this MSI motherboard features DVI and a VGA video output. No matter what screen type you want to connect, using a dedicated graphics card or an onboard connector, MSI motherboards have you covered.
MSI Z170A PC MATE - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB 3.1 Gen 2 2 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x LAN (Gigabit Ethernet) , 1 x DVI , 4 x USB 3.1 Gen 1 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x VGA , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.1 Gen 2
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
M-Flash
Hardware Features
All-Solid Capacitor motherboard Design, AMD CrossFireX technology support, MSI Military Class IV, 4K Ultra HD ready, MSI Audio Boost, Debug LED
I/O back cover
2 x Serial ATA cable
