MSI Z170A MPOWER GAMING TITANIUM ATX Intel Z170 S1151 DDR4 USB3.1
Quicklinx: CB0XWS00 Mfr#: Z170A MPOWER GAMING TITANIUM
Titanium alloys are used in the spacecraft technology and military equipment. Offering extreme strength, lightweight and the ability to withstand high temperatures it’s perfect to use on motherboards. TITANIUM motherboards’ extreme performance and their outstanding reliability is highlighted by its truly unique silver look and feel.
  • Master the game
    To master the game you need a masterful system. The MSI Enthusiast GAMING motherboards are honored with the suffix "M for Master" to cite its truly outstanding design, ready to guide you to the next level in gaming.
  • Performance and stability
    With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability. Steel Armor technology is now also available for DDR4 Boost, offering better EMI-shielding and even better signal strength, for optimal memory performance.
  • Titanium backplate
    Besides looking formidable, the TITANIUM Armor backplate strengthens the board so you can use the biggest and heaviest graphics cards and CPU coolers available.
  • Unique silver cover design
    This awesome looking protective shield helps to prevent interference from other components.
  • Titanium strength
    Titanium on the in- & outside. To deliver the best performance, this motherboard is designed with Titanium strengthened PCB and Titanium chokes.
  • Heavy plated heatsink design
    Silver heavy played premium heatsinks make sure your system stays cool during even the longest overclocking or gaming sessions.
  • Unique silver design ready for anything
    Black & white heavy played premium heatsinks make sure your system stays cool during even the longest gaming sessions.
  • Dominate the game with lowest latency
    Get ready to crush your enemies on the battlefield with MSI GAMING LAN, featuring carefully selected components to ensure the best online gaming experience without lag.
  • Dedicated gaming lan with Intel
    Experience a more fluid game with Intel i218 LAN. Intel i218 LAN is designed to deliver high performance when gaming, delivering more throughput than other solutions. Intel i218 LAN is optimized for championship level online and LAN eSports by reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This way, your CPU can be used more effectively and you can enjoy more FPS when gaming.
  • Gaming optimized bandwith management
    Dedicated to giving you the best online gaming experience with optimized traffic prioritization and low latency, MSI GAMING LAN Manager automatically classifies and prioritizes the latency-sensitive applications for online games.
  • LAN protect
    Featuring 15KV anti-surge protection to shield your network from lightning strikes and static electricity, LAN Protect is a LAN connector designed to give you the best networking experience. It's highlighted with a red LED inside the RJ45 connector to show its functionality.
MSI Z170A MPOWER GAMING TITANIUM - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2, 1 x U.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB-C Gen 1 + 1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 4 x USB 2.0 + (4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - 2 devices - RAID 0 / RAID 1 , PCIe 3.0 -connectors: 1 x U.2
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x HDMI , 1 x USB 3.1 Gen 2 , 1 x DVI-D , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen 1 , 1 x TOSLINK , 1 x USB-C Gen2
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB 3.1 Gen 1 - Type C
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
UEFI BIOS, MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Super Charger, AMD 3-way CrossFireX technology support, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, Nahimic Audio Enhacer, MSI Steel Armor, MSI Audio Boost 3, Game Boost, MSI Military Class V, LAN Protect, Double ESD Protection, OC Engine 2, OC Essentials, SteelSeries Certified (SSC), USB Redriver
Cable labels, I/O back cover
Software Included
RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, XSplit Gamecaster 2.5 (1 year premium licence)
30.5 cm
24.4 cm
Limited warranty - parts and labour - 3 years
