MSI Z170A GAMING M7 Intel Z170 LGA1151 DDR4 PCIe USB 3.1 ATX
Quicklinx: BJPVWS00 Mfr#: Z170A GAMING M7
The MSI® Z170A GAMING M7 motherboard is designed to provide gamers the best gaming experience through genuine GAMING design, best-in-class gaming features and the latest technology. The Z170A GAMING M7 motherboard is an engineering masterpiece tailored to gaming perfection.
DDR4 BOOST & XMP LED
By fully isolating the memory circuitry from other components, DDR4 Boost ensures the memory signal to stay pure for maximum performance and stability.
GAME BOOST
Generate more FPS in games! Use the Game Boost dial with automated overclocking settings that goes up to eleven and reach for 5GHz.
AUDIO BOOST 3 & NAHIMIC
The ultimate audio solution for gamers, powered by Nahimic Audio Enhancer. With dual OPA1652 AMPs and metal EMI Shielding you get breathtaking sound quality.
MSI GAMING LAN POWERED BY KILLER™
MSI GAMING LAN is powered by the KillerTM LAN E2400 Network Controller featuring intelligent AES 2.0 to automatically prioritize games above other applications. GAMING LAN uses LAN Protect with 15KV anti-surge protection for safety, highlighted with a red LED in the LAN port.
SPECIFICATIONS
Supports 6th Gen Intel® Core™ / Pentium® / Celeron® Processors
CPU socket LGA 1151
Intel® Z170 Chipset
Graphics interface - 3 * PCI-E 3.0 x16, Steel Armor PCI-E slots, 2-Way NVIDIA® SLI®, 3-Way AMD CrossFire™ support
Display Interface - 1 * DisplayPort, 2 * HDMI - Requires Processor Graphics
Memory support - 4 DIMMs, Dual Channel DDR4-3600+(OC)
Expansion slots - 4 * PCI-E x1 slots
M.2 / SATA - 2 * M.2 32 Gb/s, 6 * SATA 6 Gb/s (4 ports reserved for SATA Express)
SATA RAID - RAID 0, 1, 5, 10 - Available on SATA1 to SATA6
USB - 1 * USB 3.1 Gen2 Type-C, 1 * USB 3.1 Gen2 Type-A, 6* USB 3.1 Gen1, 7 * USB 2.0
LAN - 1 * Killer™ E2400 Gigabit LAN
Audio - 8-channel Audio Boost 3 with Nahimic
MSI Z170A GAMING M7 - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA Express port, 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 3 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Killer Gaming E2400
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x8, x4 or x8, x8, x2 modes; single card: x16 mode) , 4 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 3 x USB 2.0 , 2 x HDMI , 1 x USB 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen 1 , 1 x USB-C Gen2 , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, UEFI BIOS, BIOS FlashBack+, MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Hi-c CAP, Super Charger, Fanless Design Heatsink, AMD 3-way CrossFireX technology support, Easy Button 3, Clear CMOS Button, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, Nahimic Audio Enhacer, MSI Steel Armor, MSI Audio Boost 3, Game Boost, MSI Military Class V, LAN Protect, Double ESD Protection, OC Engine 2, OC Essentials, V-Check Points 2 Lite, SteelSeries Certified (SSC)
"Do-Not-Disturb" door hanger, case badge, cable labels, I/O back cover
Software Included
RAMdisk, MSI Gaming App, MSI Gaming Hotkey
Plug and Play
30.5 cm
24.4 cm
