The MSI® Z170A GAMING M7 motherboard is designed to provide gamers the best gaming experience through genuine GAMING design, best-in-class gaming features and the latest technology. The Z170A GAMING M7 motherboard is an engineering masterpiece tailored to gaming perfection.
DDR4 BOOST & XMP LED
By fully isolating the memory circuitry from other components, DDR4 Boost ensures the memory signal to stay pure for maximum performance and stability.
GAME BOOST
Generate more FPS in games! Use the Game Boost dial with automated overclocking settings that goes up to eleven and reach for 5GHz.
AUDIO BOOST 3 & NAHIMIC
The ultimate audio solution for gamers, powered by Nahimic Audio Enhancer. With dual OPA1652 AMPs and metal EMI Shielding you get breathtaking sound quality.
MSI GAMING LAN POWERED BY KILLER™
MSI GAMING LAN is powered by the KillerTM LAN E2400 Network Controller featuring intelligent AES 2.0 to automatically prioritize games above other applications. GAMING LAN uses LAN Protect with 15KV anti-surge protection for safety, highlighted with a red LED in the LAN port.
SPECIFICATIONS
Supports 6th Gen Intel® Core™ / Pentium® / Celeron® Processors
CPU socket LGA 1151
Intel® Z170 Chipset
Graphics interface - 3 * PCI-E 3.0 x16, Steel Armor PCI-E slots, 2-Way NVIDIA® SLI®, 3-Way AMD CrossFire™ support
Display Interface - 1 * DisplayPort, 2 * HDMI - Requires Processor Graphics
Memory support - 4 DIMMs, Dual Channel DDR4-3600+(OC)
Expansion slots - 4 * PCI-E x1 slots
M.2 / SATA - 2 * M.2 32 Gb/s, 6 * SATA 6 Gb/s (4 ports reserved for SATA Express)
SATA RAID - RAID 0, 1, 5, 10 - Available on SATA1 to SATA6
USB - 1 * USB 3.1 Gen2 Type-C, 1 * USB 3.1 Gen2 Type-A, 6* USB 3.1 Gen1, 7 * USB 2.0
LAN - 1 * Killer™ E2400 Gigabit LAN
Audio - 8-channel Audio Boost 3 with Nahimic
- MSI Z170A GAMING M7 - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA Express port, 2 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 3 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Killer Gaming E2400
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x8, x4 or x8, x8, x2 modes; single card: x16 mode) , 4 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 3 x USB 2.0 , 2 x HDMI , 1 x USB 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen 1 , 1 x USB-C Gen2 , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, UEFI BIOS, BIOS FlashBack+, MSI ClickBIOS 5
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Hi-c CAP, Super Charger, Fanless Design Heatsink, AMD 3-way CrossFireX technology support, Easy Button 3, Clear CMOS Button, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, Nahimic Audio Enhacer, MSI Steel Armor, MSI Audio Boost 3, Game Boost, MSI Military Class V, LAN Protect, Double ESD Protection, OC Engine 2, OC Essentials, V-Check Points 2 Lite, SteelSeries Certified (SSC)
- Included Accessories
- "Do-Not-Disturb" door hanger, case badge, cable labels, I/O back cover
- Software Included
- RAMdisk, MSI Gaming App, MSI Gaming Hotkey
- Plug and Play
- 30.5 cm
- 24.4 cm
