Product
Brand
MSI X99A XPower AC Intel X99 LGA2011-v3 DDR4 USB 3.0, USB 3.1, E-ATX
Quicklinx: B7QSWS00 Mfr#: X99A XPOWER AC
  • Bluetooth 4.0
  • IEEE 802.11n
The OC PCB used for the MSI overclocking motherboards has an excellent design in which 50% more layers are used compared to standard motherboards. This allows optimize all traces for overclocking. Power and signal traces are isolated, resulting in higher efficiency and performance and more features can be installed relatively close to each other without causing interference.
MSI engineers made sure you can enjoy high speed DDR4 compatibility. DDR4 brings higher memory speeds at even lower power usage as low as 1.2v. DDR4 offers higher volume sticks, this means larger memory configurations are possible up to 128GB.
Direct USB allows for faster and more convenient ways of saving scores, flashing the BIOS and installing drivers & software when overclocking on an open test bed. The Direct USB connector also allows for easy pre-testing of your hardware prior to installing it in a PC case.
MSI X99A XPOWER AC - motherboard - extended ATX - LGA2011-v3 Socket - X99
Motherboard - extended ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, registered, unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 8 x USB 3.0 + 3 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2133 MHz, 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Registered, unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I210-AT / I218V / Dual Band Wireless-AC 7260
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 5 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode) , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
2 x USB 3.1 , 2 x USB 2.0 , 8 x USB 3.0 , 1 x PS/2 keyboard / mouse , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x USB 2.0 - Type A
Power Connectors
24-pin main power connector, 8-pin ATX12V connector, 2 x 4-pin ATX12V connectors
BIOS Features
DMI support, MSI DrMOS, MSI ClickBIOS 4, MSI MultiBIOS II
Hardware Features
MSI Direct OC, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Hi-c CAP, Super Ferrite Choke (SFC), NVIDIA 4-way SLI Technology Support, Onboard Button, Easy Button 3, AMD 4-way CrossFireX technology support, OC Certified, DigitALL Power, MSI Military Class IV, OC Genie 4, MSI OC PCB, MSI Audio Boost, GO2BIOS, Gold Plated Audio Hardware, Clear CMOS Button, MSI CeaseFire, overcurrent protection, MSI Guard-Pro, dual headphone amplifiers, Debug LED, protective I/O cover, Turbo M.2, MSI ECO Power, V-Check Points 2, MSI OC Backplate, MSI OC Fan Stand
I/O back plate, "Do-Not-Disturb" door hanger, case badge, cable labels
Software Included
MSI Command Center, RAMdisk, MSI OC Pen Drive
Plug and Play
30.5 cm
27.2 cm
