USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII! Transferring your favorite games, music and movies over USB has never been faster.
Enjoy a blazing fast system boot up and insanely fast loading of applications and games with selected MSI motherboards. M.2 and SATA Express transfer data through a PCI Express 2.0 x2 interface up to 10 Gb/s, making it 67% faster than SATA 3.0 solutions.
M.2 is the successor to mSATA, offering a 67% performance increase up to 10 Gb/s. M.2 is packed in a small form factor and is compatible with 3 different sizes to fit most storage solutions.
SATA Express ia a solution in high speed storage through PCI Express, providing more bandwidth for the latest generation SSDs.
USB 3.1
USB 3.1 allows for faster speeds. USB 3.1 is even faster than SATA III! Transferring your favorite games, music and movies over USB has never been faster. -
Push your SSD even harder with Turbo M.2
Delivering high speeds, Turbo M.2 is faster than a regular SATA III connection! Enjoy a blazing fast system boot up and insanely fast loading of applications and games with MSI motherboards. -
Audio Boost
Reward your ears with true quality. Get ready for ear-drum shattering sound, with MSI Audio Boost! Because the complete audio circuitry is isolated from other features, you'll enjoy less interference and more stability. The built-in headphone amplifier allows you to use studio-grade headgear and get an amazing sound quality out of your PC. -
Military Class 4
Military Class 4 is the next step in high quality components. The Hi-c Cap, Super Ferrite Choke and Solid CAPs will make sure that your PC runs more stable under extreme gaming conditions. -
Circuit protection
Carefully selected materials, multiple PCB layers and shielding result in a perfect circuit protection for motherboards. -
OC Genie 4
Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease.
- MSI X99A SLI - Krait Edition - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 + 6 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Intel I210-AT
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 2 x USB 3.1 , 2 x USB 2.0 , 6 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, MSI DrMOS, MSI ClickBIOS 4, MSI MultiBIOS II
- Hardware Features
- V-Check Points, NVIDIA 3-way SLI Technology Support, Hi-c CAP, Super Ferrite Choke (SFC), AMD 3-way CrossFireX technology support, Onboard Button, Easy Button 3, 12 Phase Digital PWM, MSI Military Class IV, OC Genie 4, MSI Fast Boot, MSI Audio Boost, GO2BIOS, Clear CMOS Button, MSI Guard-Pro, Turbo M.2
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI ECO Center
- Plug and Play
- 30.5 cm
- 24.4 cm
