MSI X99A MPOWER Intel X99 LGA2011-v3 DDR4 USB3.0 USB3.1 ATX
Quicklinx: B7QPWS00 Mfr#: X99A MPOWER
USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII!
MSI engineers made sure you can enjoy high speed DDR4 compatibility. DDR4 offers higher volume sticks, this means larger memory configurations are possible.
Run into unstable situations when pushing your CPU to the limit? This occurs because the internal clocks are linked through the 100 MHz BCLK strap. Thanks to a integrated Clock Generator, MSI motherboards support more flexible BCLK adjustments, from 100 / 125 / 167 MHz straps. Using these straps prevents system crashing while overclocking on the edge and opens doors to achieve the absolute maximum. The MSI X99 motherboards all come with the next generation Clock Generator offering even lower jitter and power consumption resulting in even higher stability under extreme conditions.
  • MSI USB 3.1
  • DDR4 - more speed, more bandwidth, less power
  • OC engine
  • OC essentials
    A small set of tools that are essential to get the best performance out of your motherboard. These features increase stability, assist in trouble shooting, allow you to keep your complete system in check and allow for simple management. This way you can keep your mind on overclocking.
  • Optimized for multiple graphics cards
    MSI Overclocking motherboards feature perfectly aligned PCI-Express 3.0 slots with enough space for an optimal airflow when using multiple graphics cards. That way, you will never have to worry about an overheating PC, while you are enjoying the best graphics jumping off from your monitor when running a NVIDIA SLI or AMD CrossFire gaming setup.
  • Ceasefire Lite
    When you are overclocking with LN2 and 4 VGA cards and simply want to benchmark using 3 or less VGA cards you don't have to physically remove one or more cards thanks to CeaseFire Lite, saving you a lot of time. With MSI CeaseFire Lite it is very easy to disable one of the PCI-E x16 slots with a simple switch in the BIOS.
  • Fast storage WITH SATA Express
    SATA Express introduces a solution in high speed storage through PCI-Express, providing more bandwidth for the latest generation SSDs up to 10 Gb/s.
  • Push your ssd even harder with Turbo M.2
    Delivering speeds up to 32Gb/s using Gen3 x4, Turbo M.2 is more than 5 times faster than a regular SATA III connection! Enjoy a blazing fast system boot up and insanely fast loading of applications and games with MSI motherboards.
  • Next generation M.2
    Turbo M.2 is the successor to M.2 10 Gb/s, offering 3 times more performance up to 32 Gb/s using Gen3 x4. M.2 is packed in a small form factor and is compatible with 3 different sizes to fit most storage solutions.
  • Military class 4 components
    Military Class 4 is the next step in high quality components. The DrMOS II, Hi-C Cap, Super Ferrite Choke and Solid Caps will make sure that your PC runs more stable under extreme conditions.
  • DrMOS
    DrMOS is the next-gen Mosfet which is used to deliver the power for the CPU. MSI DrMOS does not waste much power, stays cool and is more power efficient than other powersaving solutions. Because DrMOS is a 3-in-1 chip it delivers much more power with less components needed. This solution gives you the power to break world records.
  • Hi-c CAP
    A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market.
  • Dark cap
    With their aluminum core design, Dark CAP's have been a staple in high-end motherboard design and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan.
  • Super Ferrite Choke
    Super Ferrite Choke uses a Ferrite core that is Super-Permeable. This allows the Super Ferrite Choke to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
  • Focus on quality
    To achieve the highest quality the MSI Overclocking motherboards are developed by the most senior engineers on the most advanced production lines.
  • Circuit protection
    Carefully selected materials, multiple PCB layers and shielding result in the best circuit protection for these overclocking motherboards.
  • ECO power
    With MSI ECO Center you can physically cut the power to unused chips to save up to 19% power usage.
  • Humidity protection
    10% reduction in moisture absorption helps prevent "Conductive Anodic Filament". Untreated PCB's can have 10x higher failure rate.
  • High temperature protection
    All key components used in MSI motherboards have all passed military testing ensuring stable operation in the harshest environments.
  • ESD protection
    Each and every I/O port is protected against the hazards of Electro Static Discharge.
MSI X99A MPOWER - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 6 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2133 MHz, 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I210-AT
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
2 x USB 3.1 , 2 x USB 2.0 , 6 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, MSI DrMOS, MSI ClickBIOS 4, MSI MultiBIOS II
Hardware Features
NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Hi-c CAP, Super Ferrite Choke (SFC), AMD 3-way CrossFireX technology support, Onboard Button, Easy Button 3, OC Certified, MSI Military Class IV, OC Genie 4, MSI Audio Boost, GO2BIOS, Clear CMOS Button, MSI Guard-Pro, dual headphone amplifiers, Debug LED, Turbo M.2, V-Check Points 2
I/O back plate, "Do-Not-Disturb" door hanger, case badge, cable labels
Software Included
MSI Command Center, RAMdisk
Plug and Play
30.48 cm
24.38 cm
