MSI GAMING motherboards are designed to provide gamers with outstanding features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection. Assemble and edit your recordings using the simple and straightforward video editor. Game Capture Auto Detect allows for automatic streaming when starting a game.
Let the games begin
MSI GAMING motherboards are designed to provide gamers with outstanding features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection. -
MSI USB 3.1 2x faster
USB 3.1 allows for high speeds, doubling the speed compared to USB 3.0 and faster than legacy USB 2.0. USB 3.1 is even faster than SATA III! Transferring your favorite games, music and movies over USB has never been faster. -
Video editor and game detection
Assemble and edit your recordings using the simple and straightforward video editor. Game Capture Auto Detect allows for automatic streaming when starting a game. -
OC engine
Run into unstable situations when pushing your CPU to the limit? This occurs because the internal clocks are linked through the 100 MHz BCLK strap. Thanks to a integrated Clock Generator, MSI motherboards support more flexible BCLK adjustments. Using these straps prevents system crashing while overclocking on the edge and opens doors to achieve the absolute maximum. The MSI X99 motherboards all come with the next generation Clock Generator offering even lower jitter and power consumption resulting in even higher stability under extreme conditions. -
Isolated audio PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Audio Boost 2 acts like a dedicated soundcard by physically isolating the audio circuitry which is separated by a red LED path. Less interference gives you a more clear audio signal. -
Direct audio power
Enjoy a heavy caliber audio experience with Direct Audio Power. A dedicated power input to Audio Boost 2 allows for a more powerful and stable power delivery, resulting in a more explosive and pure sound experience. -
Creative Sound Blaster Cinema 2
Thanks to Creative Sound Blaster Cinema 2, you're getting amazing surround sound with just stereo headphones or speakers. Creative Sound Blaster Cinema 2 enables you to clearly hear specific sounds in gaming environments. Hear your enemies perfectly, make your ears a decisive tool to finish on top. -
EMI shielding
To shield the audio core from EMI caused by other add-in cards the audio chip is protected by a high-grade EMI cover with backlight illumination. -
Dedicated headhpone amplifier
The built-in dedicated headphone amplifier rewards your high quality headphone with amazing studio level sound quality delivered from your gaming PC. Tired of having to connect your headset in difficult to reach places? MSI GAMING motherboards are designed to be easy to use, featuring front & rear audio outputs fueled by Audio Boost 2. -
USB audio power
When connecting multiple USB devices, most motherboards will be unable to deliver a strong power signal to all USB ports. This is highly noticeable with high-quality external USB DACs where sound quality degrades as the motherboard is unable to deliver a perfect USB signal.
- MSI X99A GODLIKE GAMING CARBON - motherboard - extended ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - extended ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 3400 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Registered, unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- 2 x Killer Gaming E2400 / 1535
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 5 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode)
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x PS/2 keyboard / mouse , 2 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out/headphones - phone stereo 6.3 mm , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK , 4 x USB 3.1 Gen 1
- Internal Interfaces
- 4 x USB 3.1 Gen 1 - header , 4 x USB 2.0 - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, MSI DrMOS, MSI ClickBIOS 4
- Hardware Features
- V-Check Points, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Hi-c CAP, Super Charger, Super Ferrite Choke (SFC), NVIDIA 4-way SLI Technology Support, Onboard Button, AMD 4-way CrossFireX technology support, DigitALL Power, MSI Military Class IV, OC Genie 4, MSI OC PCB, Gold Plated Audio Hardware, Clear CMOS Button, overcurrent protection, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, Turbo M.2, Dragon Armor, MSI USB Audio Power, MSI Mystic Light, Killer DoubleShot-X3 PRO, Turbo U.2, MSI Audio Boost 3 RPO, Nahimic Audio Enhacer, MSI Steel Armor, Double ESD Protection, OC Essentials, SteelSeries Certified (SSC), USB Redriver
- Included Accessories
- I/O back plate, "Do-Not-Disturb" door hanger, case badge
- Software Included
- MSI Command Center, Killer Network Manager, RAMdisk, MSI Gaming App, MSI CPU-Z
- Plug and Play
- 30.5 cm
- 27.2 cm
