Supports AMD RYZEN Series processors and 7th Gen A-series / AthlonTM Processors for socket AM4. Supports DDR4-3200+(OC) Memory. DDR4 Boost: Give your DDR4 memory a performance boost. VR Ready and VR Boost: Best virtual reality game experience without latency, reduces motion sickness. Lightning Fast Game experience: Turbo M.2, Lightning USB 3.1 Gen2. Audio Boost: Reward your ears with studio grade sound quality for the most immersive gaming experience. GAMING LAN with LAN Protect: The best online gaming experience with lowest latency and bandwidth management. Military Class 4, Guard-Pro: Latest evolution in high quality components for best protection and efficiency. MULTI-GPU: With Steel Armor PCI-E slots. Supports NVIDIA SLI & AMD Crossfire. Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click. In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost. EZ Debug LED: Easiest way to troubleshoot. Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function. GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players.
Stay cool while gaming
Cooling your PC is essential for reliable performance. They have made sure to include enough fan headers with full control to allow you to cool your system any way you want. -
Your in-game advantage
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills. -
Be the first on the battlefield
This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Immerse yourself into virtual worlds
Integrating the very best of cutting edge technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience in which content truly comes alive. -
Sound that pulls you into the game
Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay.
- MSI X370 GAMING PLUS - motherboard - ATX - Socket AM4 - AMD X370
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2048 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC (operate in non-ECC mode)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Graphics
- 2048 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x0, x8/x8 mode (with AMD Ryzen CPU); x8/x0 mode (with AMD 7th Generation A-series/Athlon CPU)) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode)
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 2 x USB 2.0 , 1 x DVI-D
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
- WHQL
- 30.4 cm
- 24.3 cm
