MSI X370 GAMING PLUS AMD AM4 X370 DDR4 M.2 USB3.1 ATX
Quicklinx: D0Q2WS00 Mfr#: X370 GAMING PLUS
Supports AMD RYZEN Series processors and 7th Gen A-series / AthlonTM Processors for socket AM4. Supports DDR4-3200+(OC) Memory. DDR4 Boost: Give your DDR4 memory a performance boost. VR Ready and VR Boost: Best virtual reality game experience without latency, reduces motion sickness. Lightning Fast Game experience: Turbo M.2, Lightning USB 3.1 Gen2. Audio Boost: Reward your ears with studio grade sound quality for the most immersive gaming experience. GAMING LAN with LAN Protect: The best online gaming experience with lowest latency and bandwidth management. Military Class 4, Guard-Pro: Latest evolution in high quality components for best protection and efficiency. MULTI-GPU: With Steel Armor PCI-E slots. Supports NVIDIA SLI & AMD Crossfire. Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click. In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost. EZ Debug LED: Easiest way to troubleshoot. Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function. GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players.
  • Stay cool while gaming
    Cooling your PC is essential for reliable performance. They have made sure to include enough fan headers with full control to allow you to cool your system any way you want.
  • Your in-game advantage
    Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills.
  • Be the first on the battlefield
    This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies.
  • Immerse yourself into virtual worlds
    Integrating the very best of cutting edge technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience in which content truly comes alive.
  • Sound that pulls you into the game
    Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay.
MSI X370 GAMING PLUS - motherboard - ATX - Socket AM4 - AMD X370
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x0, x8/x8 mode (with AMD Ryzen CPU); x8/x0 mode (with AMD 7th Generation A-series/Athlon CPU)) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode)
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 2 x USB 2.0 , 1 x DVI-D
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect
Software Included
MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
WHQL
30.4 cm
24.3 cm
