MSI AMD Radeon R7 370 GAMING 4G
Product Specification
Model Name - R7 370 GAMING 4G Model - V305 GPU - AMD Radeon™ R7 370 Codename - Trinidad Processors - 1024 Units Core Boost/ Base Clock (OC) - 1070 / 1020 MHz Memory Clock (OC) - 5700 MHz Memory Size - 4GB GDDR5 Memory Bus - 256 bits Output - DisplayPort/HDMI/DL-DVI-I/DL-DVI-D Power Consumption/Connector - 110 W / 6-pin x1 Dimension / Weight - 258x132x37 mm / 632 g Form Factor - ATX
With every new generation of GPUs comes more performance. With every new generation of MSI TWIN FROZR we give you less noise and heat!
TWIN FROZR V Thermal Design - 18 months in the development to ensure the cards have the quality and stability to give you the FPS you need. TORX Fan Blades - Maximizes downwards airflow and air dispersion to the massive heatsink below. Airflow Control Technology - Guides more airflow directly onto the heatpipes by using special deflectors on the heatsink. SuperSU Pipe Architecture - A massive nickel-plated copper base plate connected to 8mm heatpipes on the Graphics Card. ZERO FROZR Technology - Eliminates fan noise in low-load situations by stopping the fans when they are not needed. Independent Fan Control Software - The two fans can work independently of each other. Premium White LED Controllable Lighting - Allows you to choose from 5 unique modes to set the right ambience for your gaming moments. MSI Afterburner GPU Overclocking Tool - The world's favourite cross-vendor GPU overclocking software. MSI GAMING APP - Overclocking through this app is covered by warranty to take away your worries. TWIN FROZR V
Cooler, Quieter, Better Gaming
We've listened to all your requests and the new TWIN FROZR V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI GAMING motherboard including some funky LED lightning. Our new TORX fans generates more airflow to maximize air dissipation to heatsink, while the advanced dispersion blade design generates 19% more airflow without increasing drag for supreme silent performance.
AIRFLOW CONTROL
Enhanced Dissipation Efficiency
MSI has fitted TWIN FROZR V coolers with the all new Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency.
SuperSU PIPE
SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card. Additionally, the new heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design.
ZERO FROZR
Smart Cooling, Stay Quiet
MSI's TWIN FROZR V Thermal Designs are equipped with Zero Frozr technology which was first introduced by MSI back in 2008. Zero Frozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there's a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC.
INDEPENDENT FAN CONTROL
Maximum Fan Control, Minimum Noise
The two fans on the TWIN FROZR V Thermal Design can work independently of each other*. This means you'll only have the necessary fan noise given the temperature of the components below the fan. This unique solution gives you the best balance between temperatures and noise and highlights why the MSI TWIN FROZR V is seen as the ultimate Graphics Card cooling solution.
*Availability of this feature varies by model.
CATCHING THE VIBE WITH COOL LED EFFECTS
White LED Lighting
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This brand new function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click using the MSI GAMING APP or control it from the NVIDIA GeForce Experience software.
Traditionanl fan blade
Maximizes downwards airflow and air dispersion to the massive heat sink below them. -
Dispersion fan blade
Intake more airflow to maximizes air dissipation to heat sink. -
Airflow diagram
Advanced Dispersion Blade design generates 19% more airflow without increasing drag for supreme silent performance. -
Enhanced dissipation efficiency
MSI has fitted Twin Frozr coolers with the Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency. -
SuperSU PIPE
SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card. Additionally, heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design. -
Smart cooling, stay quiet
MSI's Twin Frozr V Thermal Designs are equipped with ZeroFrozr technology which was first introduced by MSI back in 2008. ZeroFrozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there's a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC. -
Catching the vibe with cool LED effects
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click.
- MSI R7 370 GAMING 4G - graphics card - Radeon R7 370 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R7 370
- Memory
- 4 GB GDDR5
- Core Clock
- 1020 MHz
- Boost Clock
- 1070 MHz
- Effective Memory Clock
- 5.7 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
- API Supported
- OpenGL 4.4, DirectX 12
- 3.7 cm x 25.8 cm x 13.2 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon R7 370
- Core Clock
- 1020 MHz
- Boost Clock
- 1070 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 3
- API Supported
- MSI SuperPipe Technology, MSI Solid Capacitor, Dual Fan Design, AMD CrossFireX Technology, MSI Afterburner, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, Twin Frozr V Thermal Design, Torx Fans, SuperSU Architecture, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.7 GHz
- Bus Width
- 256-bit
- Additional Requirements
- 6 pin PCI Express power connector
- 110 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, MSI Afterburner, MSI Predator
- MIL-STD 810G
- 3.7 cm
- 25.8 cm
- 13.2 cm
- 632 g
