MSI Prestige PX60 Skylake i7-6700HQ 16GB 256GB SSD 15.6" Win 10P
Quicklinx: BVGZWS00 Mfr#: 9S7-16H834-064
  • Core i7
  • IEEE 802.11n
  • Bluetooth 4.0
  • NVIDIA GeForce GTX 950M
The graphics processor delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment. MSI True Color technology ensures that each panel comes with the finest precision in color. After examination and an extensive factory calibration process by MSI True Color technology, the panel quality will be more accurate. Hence, each color is delivered with the highest standard precision in detail, ensuring excellent color fidelity for many use applications.
With the Matrix Display, you can build the multi-display working or multi-media environment. Work or fun, it is possible to have both at the same time with just one MSI Prestige notebook. Inspired by boutique fashion and high-precision instruments, the MSI Prestige series is simple yet sophisticated - with metallic exterior design and the backlit keyboard in the interior.
  • Advanced desktop performance made portable
  • True Color technology
    MSI True Color technology ensures that each panel in a MSI notebook comes with the finest precision in color. After examination and an extensive factory calibration process by MSI True Color technology, the panel quality will be more accurate. Hence, each color is delivered with the highest standard precision in detail, ensuring excellent color fidelity for many use applications.
  • Matrix Display technology
  • Metallic cover
  • Hear beyond the limits, Nahimic sound technology is packed for better entertainment
    Nahimic enhances sound quality and precision, audio inputs are therefore transformed into vivid-like ones. Build your own entertainment corner and enjoy the immersive virtual sound in high definition with one laptop and with just one simple click.
  • Sound by Dynaudio
    Dynaudio delivers an authentic sound experience by boosting power amplitude, meaning a volume increase over 10 dBA. Any high quality stereo source is transformed into true-to-life, multi-channel sound. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound.
  • Audio Boost
    The MSI Audio Boost design enhances the output sound detail and sound stage. The gold flash audio jack provides stable sound transmission (reduced obstruction) and works in conjunction with the optimized headsets AMP (Audio Power Amplifier) design, with low noise and low distortion characteristics, to greatly enhance headphone performance and faithfully reproduce each acoustic detail.
  • Silver Lining Print
    See more and do more in the night with high-grade silver lining printed keys on MSI Prestige Series' single backlit and one-piece shielding design keyboard. Enjoy longer lasting keys worry free of long-term wear and tear.
  • PCIe Gen 3.0 x4 SSD - load files and data in seconds
    The latest PCIe Gen 3.0 x4 bandwidth utilizing NVMe technology on single M.2 SSD harnesses the full performance potential of the Gen 3.0 SSD through the optimization of the hardware and software, outputting extreme read speeds.
  • "SHIFT" - boost performance under controlled noise and temperature
    The MSI "SHIFT" technology pushes system to the extreme while minimizing noise and temperature. Default setting for the Prestige Series is at Sport mode. Switch between two other profiles "Green" and "Comfort" to reach balance between system performance and comfortable user experience.
  • Cooler Boost 3 - better cooling solution
    The Cooler Boost 3 technology creates a split thermal solution for the MSI Prestige Series by utilizing a total of 4 heat pipes, 2 dedicated for graphics card and 2 for processor and dual fans. This thermal solution significantly reduces system temperature by optimizing thermal dissipation with dual fans and pushing heat outside through 4 vents. Cooler Boost 3 offers optimum cooling and maintains a stable and low temperature system even after long sessions of the highest loading.
MSI PX60 6QD 064UK - 15.6" - Intel Core i7 - 6700HQ - 16 GB RAM - 256 GB SSD + 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
16 GB DDR4
Storage
256 GB SSD + 1 TB HDD / 7200 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
Silky silver
39 cm x 26.6 cm x 2.005 cm
2.1 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD M.2
Secondary Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
100% sRGB, 94% NTSC
Anti-glare, TrueColor, WideView, MSI Matrix Display
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 1080p
Sound
Four speakers, microphone
Audio Features
Output: Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Gigabit Ethernet
6-cell
AC Adapter
Output
120 Watt
Connections & Expansion
Interfaces Details
LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Silky silver
Case Material
Metal
Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
2.1 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
