MSI Prestige PX60 6QD065 Skylake i7-6700HQ 8GB 1TB 15.6" Win 10P
Quicklinx: BVH0WS00 Mfr#: 9S7-16H834-065
  • Core i7
  • IEEE 802.11n
  • Bluetooth 4.0
  • NVIDIA GeForce GTX 950M
This notebook's processor requires lower power consumption, but delivers better performance than before. The amazing graphics card brings extreme graphics performance to notebooks. It delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment. MSI True Color technology ensures that each panel in a MSI notebook features fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications.
With the Matrix Display, you can build the multi-display working or multimedia environment. Work or fun, it is possible to have both at the same time with just one MSI Prestige notebook. Inspired by boutique fashion and high-precision instruments, the MSI Prestige series is simple yet sophisticated - with silky metallic exterior design and the light backlit keyboard in the interior.
  • Powerful processor
    The processor requires lower power consumption, but delivers better performance than before.
  • Advanced desktop performance made portable
  • True Color technology
    MSI True Color technology guarantees that each panel in a MSI notebook features fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications.
  • Matrix Display technology
    As a designer or business elite, it is a must to possess multi-task ability. However, it is also extremely important to relax completely after work to keep a balanced life. With the Matrix Display, you can build the multi-display working or multi-media environment. Work or fun, it is possible to have both at the same time with just one MSI Prestige notebook.
  • Silky metallic cover
  • Nahimic Audio Enhancer
    Nahimic enhances sound quality and precision, audio inputs are therefore transformed into vivid-like ones. Build your own entertainment corner and enjoy the immersive virtual sound in high definition with one laptop and with just one simple click.
  • Sound by Dynaudio
    Dynaudio Premium Sound technology delivers an authentic sound experience by boosting power amplitude. Any high quality stereo source is transformed into true-to-life, multi-channel sound. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound.
  • Audio Boost technology
    The MSI Audio Boost design enhances the output sound detail and sound stage. The gold flash audio jack provides stable sound transmission (reduced obstruction) and works in conjunction with the optimized headsets AMP (Audio Power Amplifier) design, with low noise and low distortion characteristics, to greatly enhance headphone performance and faithfully reproduce each acoustic detail.
  • SHIFT - boost performance under controlled noise and temperature
    The exclusive MSI SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between two other profiles sport and comfort to reach balance between system performance and comfortable user experience.
  • Cooler Boost 3 - better cooling solution
    The Cooler Boost 3 technology creates a split thermal solution for the MSI Prestige series by utilizing a total of 4 heat pipes, 2 dedicated for graphics card and 2 for processor and dual fans. This thermal solution significantly reduces system temperature by optimizing thermal dissipation with dual fans and pushing heat outside through 4 vents. Cooler Boost 3 offers optimum cooling and maintains a stable and low temperature system even after long sessions of the highest loading.
MSI PX60 6QD 065UK - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
8 GB DDR4
Storage
1 TB HDD / 7200 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
Silky silver
39 cm x 26.6 cm x 2.005 cm
2.1 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Pro
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
100% sRGB, 94% NTSC
Anti-glare, TrueColor, WideView, MSI Matrix Display
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 1080p
Sound
Four speakers, microphone
Audio Features
Output: Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165 - M.2 Card
Network Interface
Gigabit Ethernet
6-cell
AC Adapter
Output
120 Watt
Connections & Expansion
Interfaces Details
LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Silky silver
Case Material
Metal
Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
2.1 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
