MSI Prestige PE70 6QE-080UK Skylake i7-6700HQ 16GB 1TB Win 10
Quicklinx: BVHHWS00 Mfr#: 9S7-16J512-022
  • Core i7
  • IEEE 802.11n
  • Bluetooth 4.0
  • NVIDIA GeForce GTX 960M
The exclusive MSI SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between three profiles Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. Heat is an original element on earth. It's pure physics that more energy will generate more heat. Cooling is therefore a knotty task to tackle with. MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system. MSI True Color technology guarantees that each panel in a MSI notebook features fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. Expand the vision for extreme gaming experience. MSI Matrix Display supports up to 2 external displays simultaneously through HDMI and Mini DisplayPort. Multitasking is made possible even during competitive gameplays. Connect the laptop to HDTV display, Matrix Display supports 4K output. MSI Matrix Display technology creates an ideal environment for extreme gaming experience and pleasant multimedia entertainment. Experience better image quality, the wide-view angle panel enhanced more contrast level and more brightness level than TN panel, with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side.
  • Boost performance under controlled noise & temperature
  • Cooler Boost 3 - keep calm under pressure
  • True Color technology
  • Matrix Display
  • Wide-viewing angle display
  • Nahimic virtual surround sound
    Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high-definition audio recorder to easily capture and stream studio quality sound.
  • Sound by Dynaudio
    Dynaudio equips the MSI Gaming series gaming notebook with top-notch audio features, creating a realistic sound and immersive effects. Dynaudio delivers an authentic sound experience by boosting power amplitude. Any high-quality stereo source is transformed into true-to-life, multi-channel sound.
  • Audio Boost 2
    By utilizing dedicated headset amplifiers, an isolated audio board and gold-plated audio jacks, Audio Boost 2 delivers advanced listening experience of any gaming notebook. Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack.
  • A keyboard all gamers desire for
    Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions.
  • Killer Gaming LAN
    In the gaming battlefield, speed defines the winner. Stop losing games to lag with Killer Gaming LAN. The advanced stream detect 2.0 protects networking traffic and prevents lag spikes through controlling and managing up to 6 priority levels.
MSI GE62 6QD 022UK Apache Pro - 15.6" - Intel Core i7 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
Notebook
Operating System
Windows 10 Home
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
8 GB DDR4
Storage
128 GB SSD + 1 TB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
38.3 cm x 26 cm x 2.9 cm
2.4 kg
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Secondary Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Audio Features
Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost 2, Nahimic sound technology
Input
Keyboard, touchpad
Keyboard Backlight
SteelSeries Engine 3, SteelSeries Full Color
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165
Network Interface
Gigabit Ethernet
Killer Shield
6-cell
AC Adapter
Output
120 Watt
Connections & Expansion
LAN , HDMI , Microphone input , Headphone output , Mini DisplayPort , 2 x USB 3.0 , USB 2.0 , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Aluminum
SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
2.4 kg
BVHH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
