The improved processor requires lower power consumption but delivers better performance. CPU performance is much faster under average usage. The graphics card brings extreme performance to this notebook. The graphics delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment.
True Color technology
MSI True Color technology guarantees that each panel in this MSI notebook comes with the fine precision in color. After examination and an extensive factory calibration process by the MSI True Color technology, the panel quality will be more accurate, close to sRGB. Hence, each color is delivered with the high standard precision in detail, guaranteeing excellent color fidelity for many use applications. -
True Color profile
Vision and sound are the extremely important two factors in this field. You now get to see clearer than your enemies to always get one step ahead of the rest. True Color technology also offers perfect color accuracy for more scenarios. Work or play, you can easily switch to the mode that optimally suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere. -
Nahimic virtual surround sound
Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. -
"SHIFT" - boost performance under controlled noise and temperature
The MSI "SHIFT" technology pushes system to the extreme while minimizing noise and temperature. Switch between different profiles "Sport," "Comfort," and "Green" to reach balance between system performance and comfortable user experience. -
Cooler Boost 3: keep calm under pressure
MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A different heat pipes and dual fans actively and effectively push heat out of the system, resulting in better cooling effects on this incredible slim and light gaming notebook.
- MSI PE70 6QE 080UK - 17.3" - Intel Core i7 - 6700HQ - 16 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 16 GB DDR4
- Storage
- 1 TB HDD
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 960M
- Video Memory
- 2 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell
- Silky silver
- 41.9 cm x 28 cm x 2.9 cm
- 2.6 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Sound
- Four speakers, subwoofer, microphone
- Audio Features
- Output: Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology
Input
- Keyboard, touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Miracast
- Technology
- 6-cell
AC Adapter
- Output
- 120 Watt
Connections & Expansion
- Interfaces Details
- LAN , HDMI , Microphone input , Headphone output , Mini DisplayPort , 2 x USB 3.0 , USB 2.0 , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Silky silver
- Security lock slot (cable lock sold separately), Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 2.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
