MSI Prestige PE70 6QE-080UK Skylake i7 6700HQ 16GB 1TB 17.3" W10
Quicklinx: BVHJWS00 Mfr#: 9S7-179542-080
  • Core i7
  • IEEE 802.11n
  • Bluetooth 4.0
  • NVIDIA GeForce GTX 960M
The improved processor requires lower power consumption but delivers better performance. CPU performance is much faster under average usage. The graphics card brings extreme performance to this notebook. The graphics delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment.
  • True Color technology
    MSI True Color technology guarantees that each panel in this MSI notebook comes with the fine precision in color. After examination and an extensive factory calibration process by the MSI True Color technology, the panel quality will be more accurate, close to sRGB. Hence, each color is delivered with the high standard precision in detail, guaranteeing excellent color fidelity for many use applications.
  • True Color profile
    Vision and sound are the extremely important two factors in this field. You now get to see clearer than your enemies to always get one step ahead of the rest. True Color technology also offers perfect color accuracy for more scenarios. Work or play, you can easily switch to the mode that optimally suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere.
  • Nahimic virtual surround sound
    Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound.
  • "SHIFT" - boost performance under controlled noise and temperature
    The MSI "SHIFT" technology pushes system to the extreme while minimizing noise and temperature. Switch between different profiles "Sport," "Comfort," and "Green" to reach balance between system performance and comfortable user experience.
  • Cooler Boost 3: keep calm under pressure
    MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A different heat pipes and dual fans actively and effectively push heat out of the system, resulting in better cooling effects on this incredible slim and light gaming notebook.
MSI PE70 6QE 080UK - 17.3" - Intel Core i7 - 6700HQ - 16 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
16 GB DDR4
Storage
1 TB HDD
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
Silky silver
41.9 cm x 28 cm x 2.9 cm
2.6 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 2 years - pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
1 TB HDD SATA 6Gb/s
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 720p
Sound
Four speakers, subwoofer, microphone
Audio Features
Output: Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Gigabit Ethernet
Miracast
6-cell
AC Adapter
Output
120 Watt
Connections & Expansion
Interfaces Details
LAN , HDMI , Microphone input , Headphone output , Mini DisplayPort , 2 x USB 3.0 , USB 2.0 , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Silky silver
Security lock slot (cable lock sold separately), Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
2.6 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
