MSI NVIDIA GeForce GTX 1080 8GB GAMING X
Quicklinx: C4KLWS00 Mfr#: GTX1080-GAMING-X-8G
1 on order, delivery delayed
GeForce® GTX 1080 GAMING X 8G
Core/Memory:
• Boost Clock / Base Clock
1847 MHz / 1708 MHz (OC Mode)
1822 MHz / 1683 MHz (Gaming Mode)
1733 MHz / 1607 MHz (Silent Mode)
• 8192 MB GDDR5X / 10108 MHz Memory
Video Output Function:
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Features:
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY:
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing.
A BETTER GAMING EXPERIENCE:
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY:
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
  • Get game ready with GeForce GTX
    Discover unprecedented performance, power efficiency, and amazing gaming experience with GeForce GTX graphics cards.
  • Torx 2.0 fan - teamwork for greater strength
    Just like in games, the exclusive MSI Torx 2.0 Fan technology uses the power of teamwork to allow the Twin Frozr VI to achieve new levels of cool. Torx 2.0 Fan design generates more air pressure for supremely silent performance in the heat of battle.
  • Double Ball Bearings
    Double Ball Bearings give the unique MSI Torx 2.0 Fans a strong and lasting core for years of smooth gaming. They also remain virtually silent while spinning under load, keeping your graphics card cool during intense and lengthy gaming sessions.
  • Zero Frozr - stay undetected
    Zero Frozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
  • Catch the vibe with cool LED effects
    Each LED can be controlled individually by choosing any of the animation effects available in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
  • Cool & quiet gaming experience
    Lurking under the cover of the Gaming graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool & quiet gaming experience.
  • AirFlow Control technology
    Using advanced aerodynamics, Airflow Control technology directs more air directly onto the Twin Frozr VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
  • Smooth heat pipes
    Up to 8 mm thick copper heat pipes with a smooth squared shape at the bottom maximize heat transfer from the surface of the copper base plate.
  • Solid baseplate
    To temper the heat generated by a powerful GPU, MSI Gaming series graphics cards use a solid nickel-plated copper base plate. The base plate catches the heat from the GPU and transfers it to the heat pipes for dissipation so you can keep cool.
  • Premium thermal compound
    Every detail counts when it comes to creating the ultimate thermal design, which is why Twin Frozr VI uses a premium thermal compound to make sure it outlives the competition.
  • Close quarters cooling
    Below the heatsink you find the close quarters cooling which enables you to push the MSI Gaming card to the max.
  • Extra power input
    A tailored PCB design higher performance and extra cooling comes with an extra 6-pin connector to allow for overclocking beyond the limits.
MSI GTX 1080 GAMING X 8G - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
8 GB GDDR5X
Core Clock
1708 MHz
Boost Clock
1847 MHz
Effective Memory Clock
10.108 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.2 cm x 27.9 cm x 14 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1708 MHz
Boost Clock
1847 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia SLI Multi-GPU Technology, MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia 2-way SLI ready, MSI Afterburner, Twin Frozr IV Thermal Design, MSI Gaming App, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, Torx Fans, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, Nvidia SHIELD ready, 10 Phase PWM Design, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.108 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
6 pin PCI Express power connector, 8 pin PCI Express power connector
180 Watt
Software Included
MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence)
4.2 cm
27.9 cm
14 cm
1.1 kg
Limited warranty - parts and labour - 3 years
