GeForce® GTX 1060 ARMOR 3G OCV1
Core/Memory
• Boost Clock / Base Clock
1759 MHz / 1544 MHz
• 3072 MB GDDR5 / 8008 MHz Memory
Video Output Function
• DisplayPort x 2
• HDMI x 2
• Dual-link DVI-D x 1
• Virtual Reality Ready
• DirectX 12 Ready
• Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
- MSI GTX 1060 ARMOR 3G OC - graphics card - GF GTX 1060 - 3 GB - black, white
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4.1 cm x 27.5 cm x 13.7 cm
- Enclosure Colour
- Black, white
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Dual Fan Design, MSI Afterburner, Airflow Control technology, NVIDIA G-Sync ready, NVIDIA GameWorks, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- 120 Watt
- Software Included
- MSI Afterburner
- 4.1 cm
- 27.5 cm
- 13.7 cm
- 689 g
- Enclosure Colour
- Black, white
